Can create iscsi lun greater than 16TB
peter.rogers
Post by peter.rogers »
HI All,
I currently have a F5-422 unit with 4 x 14TB drives setup as Raid 5 giving me approx 38TB of usable space.
I am trying to create a new iscsi volume so i can mount the space on my windows backup server.
Everytime i try and create a drive greater than 16TB i get an error
Warning: Division by zero in /usr/www/include/class/iscsiadm.class.php on line 762
and it seems to create a 0 byte lun which cant be connected to via windows,
if i create a LUN of 16000gb it seems to work fine,
How do a create a single Lun to connect to my server?
just updated to firmware 4.2.15-2107221409 which seems to be the latest version available via auto update.
any help would be great,
Peter
Re: Can create iscsi lun greater than 16TB
Hi! Is the file system of the volume Ext4? Under Ext4, only 16TB LUNs can be created. It is recommended to set the file system to Btrfs.
peter.rogers
Hi Support,
Thanks for that, yes it was formatted ext4. I have recreated the Volume and was able to create a new LUN at the full 40TB size,
Now to check if its stable.
Peter
