How to to direct files to different discs?
burakdeniz89
Post by burakdeniz89 »
In the brief time i was able to do some configuration of my F5-221 NAS (faulty sent back for replacement) i had added three HDDs and configured two to RAID1 and one as a single disc and would have been adding two more as single discs later and in the process i couldn't find a way to direct where a file i wanted to save was to reside IE the RAID1 or the single disc so the question is how do i do this in future when i have one RAID1 and three single discs?
joprysko
Re: How to to direct files to different discs?
Post by joprysko »
After you create a volumes for each drive you simply need to create a shared folder on each drive. Then you map to the shared folder.
Hope that helps.
