Hello, I just received my F5-422 / 10 Gbe.
I installed on it 3 Exon HDDs of 16Tb each.
The RAID 5 synchronization is currently in progress (I'm at 10% after 3 hours of installation).
For the moment the write speeds are much worse than on all my other systems, almost unusable.
Is this normal considering the RAID is under construction? I don't have to worry about it?
Thank you!
RAID synchronization, very bad performance
Re: RAID synchronization, very bad performance
{L_BUTTON_AT}Etienne
@etienne
I just rebuilt RAID 1 on F2-221 using ext4 on 2 x WD 4tb Reds. The synchronization process took 13 hours and 10 minutes. I don't recall how long it took when I originally built the RAID 1 using BTRFS but it seemed to take less time.
