Cannot mount after RAID5 recovery
SMB, NFS, AFP, FTP, web file manager and Rsync server.
jbeazell
Post by jbeazell »
I'm getting the following when I attempt to mount the RAID:
-bash-4.4# mount /dev/mapper/vg0-lv0 /mnt/md0/
mount: /mnt/md0: wrong fs type, bad option, bad superblock on /dev/mapper/vg0-lv0, missing codepage or helper program, or other error.
-bash-4.4# mount: /mnt/md0: wrong fs type, bad option, bad superblock on /dev/mapper/vg0-lv0, missing codepage or helper program, or other error.
The array looks OK:
-bash-4.4# cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [multipath]
md0 : active raid5 sdb4[0] sda4[4] sdd4[2] sdc4[1]
17571293184 blocks super 1.2 level 5, 128k chunk, algorithm 2 [4/4] [UUUU]
bitmap: 0/44 pages [0KB], 65536KB chunk
-bash-4.4# mdadm -D /dev/md0
/dev/md0:
Version : 1.2
Creation Time : Mon Mar 30 15:44:30 2020
Raid Level : raid5
Array Size : 17571293184 (16757.29 GiB 17993.00 GB)
Used Dev Size : 5857097728 (5585.76 GiB 5997.67 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistent
Intent Bitmap : Internal
Update Time : Tue May 19 15:04:43 2020
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 128K
UUID : cc80e7cd:c6b902c4:ef36b897:409e8f96
Events : 18518
Number Major Minor RaidDevice State
0 8 20 0 active sync /dev/sdb4
1 8 36 1 active sync /dev/sdc4
2 8 52 2 active sync /dev/sdd4
4 8 4 3 active sync /dev/sda4
I can't seem to repair it, either:
-bash-4.4# btrfs check --repair --init-extent-tree --init-csum-tree /dev/mapper/vg0-lv0
enabling repair mode
Creating a new CRC tree
couldn't open RDWR because of unsupported option features (3).
ERROR: cannot open file system
suggestions?
jbeazell
Re: Cannot mount after RAID5 recovery
Post by jbeazell »
More things I've tried:
-bash-4.4# btrfsck /dev/mapper/vg0-lv0
parent transid verify failed on 441725075456 wanted 131622 found 131618
Ignoring transid failure
leaf parent key incorrect 441725075456
-bash-4.4# btrfs rescue zero-log /dev/mapper/vg0-lv0
ERROR: could not open ctree
-bash-4.4# mount -t btrfs -o recovery,nospace_cache,nospace_cache /dev/mapper/vg0-lv0 /mnt/md0
-bash-4.4# mount -t btrfs -o ro,nospace_cache,nospace_cache /dev/mapper/vg0-lv0 /mnt/md0/
Your information has been transferred to the related dept., and will get back to you if any results.
Return to “File Services”
