f4-210 connect through USB to laptop
SMB, NFS, AFP, FTP, web file manager and Rsync server.
rapcat
Post by rapcat »
Is it possible to make connection between the TNAS f4-210 and a computer to transfer files through Usb 3.0 ???
TMRyan
Re: f4-210 connect through USB to laptop
Post by TMRyan »
No, you can only transfer files through network connection.
You can use a network cable to connect TNAS directly to the computer, and then map the folder for transmission.
If you want a hard disk box, you can take a look at our TDAS products: https://www.terra-master.com/global/pro ... o-das.html
rapcat
Post by rapcat »
It would be a good feature to have ethernet and usb connection in just one device.
Return to “File Services”
