I'm new to this forum and also with TerraMaster. I've bought one for the first time a week ago.
Now I've a question about the home folder/ user folder, because I can't use this with an application like usb copy. Is there a way to disable the home/ user folder so I can create my own folder? With my own name etc.
Thanks for your help in advance.
Arjan
Home Folder
Re: Home Folder
The user home directory is for user configuration storage, it is not used for data storage.
if you want to use a folder only for you, you can create a shared folder on your name or any name you like, and set permissions to you only and deny to anyone else. Then this folder will be your pernonal folder, a private folder.
Re: Home Folder
Yes that is what I want to do. But is there a way I can disable the user folder.
Otherwise I (and the rest of the family) will see a drive that I don't want them to use. And I can't use my own name, because that is what it's using for the user folder. I know with an other brand there was an option to disable the user folder.
It's oke for me to use another name, but I don't want to see it when I share it with smb or afp.
Re: Home Folder
In the coming new version, you can hide this folder on your network.
Re: Home Folder
That's great!!!
Re: Home Folder
It's in TOS4.2.
