webdav Certificate Problem
SMB, NFS, AFP, FTP, web file manager and Rsync server.
gretor
Post by gretor »
I am setting up a WebDav server. Everything is working so far.
In the settings of the Terra Master NAS I have selected SSL certificate Webdev. But I can not download the certificate there ( error: source file does not exist ).
If I now want to log on to the Webdav server unfortunately come unsightly certificate error message ... nothing trustworthy... and so on.
How do I get a reasonable certificate, with which I can connect the Terra master without such an error message.
Thank you very much.
greetings gretor
TNAS F2-221 - TOS 5
4 GB Ram
2x 4 TB WD Red - Raid 1
TMnorah
Re: webdav Certificate Problem
Post by TMnorah »
Hi, what version of the system are you using? We need to verify that.
{L_BUTTON_AT}gretor
The webDAV in TOS uses the default self-signed certificate from TerraMaster, due to not a CA certificate, you will be prompted with an untrusted certificate when you connect from a client. If you can confirm the certificate is from TerraMaster, you can click "Trust this certificate" and "Go ahead anyway".
gretor
Post by gretor »
OK,
this self-signed certificate is then simply called "webdev"? at least that's what it shows me in the file manager when I connect.
Why can I not "download" the "self-signed certificate" in options. Even if it is self-signed, it should be possible.
But if I press webdav and download in options, it says "source file could not be read.
greetings gretor
TNAS F2-221 - TOS 5
4 GB Ram
gretor
Post by gretor »
Okay, clicked away the certificate error message and trust the Terra Master certificate. So everything is working fine now.
But I have another question. In the settings I clicked "Enable WebDav protocol".
However, I can not find the logging for this in the settings ? There are only protocols to http , smb ftp etc. to find.
Where can I find the webdav log files ?
greetings gretor
TNAS F2-221 - TOS 5
4 GB Ram
1. Log in to the SSH terminal
2. Execute the following command.
cat /tmp/log/access_log
gretor
Post by gretor »
thank you, everything works so far.
TNAS F2-221 - TOS 5
4 GB Ram
Return to “File Services”
