I have installed TOS 5.
Unfortunately I can not establish the TNASOnline connection via https. Only a http connection is established.
The certificates are all set correctly in the settings (digizert).
This error occurs when selecting Server Europe as well as Global.
Is this a known problem ?
lg gretor
TOS 5 - TNAS.Remote Login.
TNAS F2-221 - TOS 5
4 GB Ram
2x 4 TB WD Red - Raid 1
4 GB Ram
Re: TOS 5 - TNAS.Remote Login.
Same problem.
Still waiting for an answer...
May end-up installing OpenMediaVault...
It will be fixed in the next version.
- OllieHardy
I'm sorry, but this hasn't been fixed. I have disabled European Server and chosen Both China and Gobal, and none of them work
- Charlie_Croker
If you use NordVPN, you can use the “Meshnet feature”. https://support.nordvpn.com/General-inf ... eshnet.htm
