Impossible access on TNAS F4-210
MordaniMeillis
Post by MordaniMeillis »
Hi, kids.
For several days I can not access the TNAS through Samba, or through ethernet.
Thank you for your attention.
Hardfecx
Re: Impossible access on TNAS F4-210
Post by Hardfecx »
Hey Kid,
tried SSH?
{L_BUTTON_AT}MordaniMeillis
Can the TNAS PC search for your device's IP? Does the LAN light on green? Is there any error tips when you access via the browser. If possible, please attach a screenshot of the problem.
MordaniMeillis
I attach a screenshot where you can see what takes twenty minutes without changing.
Sin título.jpg (16.41 KiB) Viewed 6744 times
When every time TNAS restart or power on, it will try to check if the file system is healthy, if there is something wrong with the file system, it will try to repair the error. in case the system fails to do that, it may be stuck on the loading page. If this happens, that means there is an uncorrectable error on your file system. you can try to restart your device and try again, if that keeps persists, you need to find a way to backup your data, or even worse, you need to find a third-party service to recover your data.
To know more about file system corruption.
MordaniMeillis
From Windows I can access the TNAS files as part of a library of videos, images, music, etc. I can play them, copy them to another device and see characteristics of the files. I can't delete or create files or folders. I can't rename files or folders. Can the file system be corrupted despite being able to play files?
The file system is corrupted. Please refer to the article to repair the file system.
MordaniMeillis
The article tells you to connect using SSH. But for this I have to access the NAS, and I can't. I have also tried to copy the files to another disk via a usb connection adapter to the PC, but the PC cannot even see the partition.
A help, please.
If you can access your device via SMB service, you can copy the files first.
Then connect the hard drive to the computer for repair.
