Can't access when on mobile or remote (not local wifi)
pieboy100
Post by pieboy100 »
Hi all
I am able to access my Terramaster when on the same network but not when on a different wifi (it can't locate the drive) or on mobile network (it just constantly does the spinning circle).
Any solutions?
Stuart
Re: Can't access when on mobile or remote (not local wifi)
If you want to access TNAS remotely, you need to go to Desktop > Remote Access and enable TNAS.online or DDNS.
byujojo
Post by byujojo »
I'm having the same issue. Even after enabling remote access and pressing apply it flashes the URL for access for a brief moment then it vanishes as if it was never there.
Under other WAN/LAN WIFI, network authentication may take about 1mins.
Return to “Network & Remote Access”
