I'm testing a new F2-221 device and I'm running in trouble with SSH access.
After adding and removing some test users I noticed that I was not able to login via SSH with super_user credential defined in the setup (in my case administrator) with "access is denied" message.
So I enabed telnet from the web interface and I logged on successfully this way.
I checked the /etc/ssh/sshd_config file and I found that the administrator username was messed up:
AllowUsers administratoristrator
I tried also renaming administrator to TOSadmin and that's what I got in the sshd_config
AllowUsers TOSTOSadmin
Can you please help me solve this trouble?
TOS version is 4.2.18-2110301149
Best regards,
Francesco
