Possible to assign a Docker or VirtualBox VM to a specific LAN port?
MooieBoot
Post by MooieBoot »
I've an F5-221 with dual 1GB LAN ports. I've attached the NAS to a managed switch with VLAN support and I would like to be able to choose which LAN port a Docker Image and VirtualBox VM will use. Is this something that can be accomplished within TOS 4? And/or will TOS 5 have some kind of VLAN support integrated?
MooieBoot
Re: Possible to assign a Docker or VirtualBox VM to a specific LAN port?
Post by MooieBoot »
I've found the setting for VirtualBox VM's to assign them to a specific interface.
Docker has it's own virtual interface, but to which LAN port is this interface connected and/or can this be set?
Hi! The setting is not supported currently.
Return to “Network & Remote Access”
