*.tnas.link SSL certificate expired
brunix86
Italy
Post by brunix86 »
The SSL certificate for *.tnas.link has expired some days ago (16/10/2021).
How I could renew it?
Or maybe it depends on the TerraMaster server which needs to be updated?
Below you can see the SSL certificate that has expired 6 days ago (the UI is in italian language):
Control Panel - SSL certificate settings
Thanks for your support
My NAS Environment
  • TNAS F4-423
  • TOS 5.1.123-00529 (8GB System Partition)
  • 2x RAM Terramaster 4GB DDR4 2133 MHZ
TMnorah
Re: *.tnas.link SSL certificate expired
Post by TMnorah »
Hello, please refer to the following forum link to download the patch package to update it: viewtopic.php?f=28&t=2535
brunix86
Italy
Post by brunix86 »
{L_BUTTON_AT}TMnorah
I just applied the patch 1.18 and the problem is solved!
Thanks for your assistance.
My NAS Environment
  • TNAS F4-423
