change time server
anyway
change time server
Post by anyway » 20 Dec 2019, 00:17
How can I change the predefined time server in order to receive date and time from a local one?
Customer Service
Re: change time server
Post by TMSupport » 20 Dec 2019, 10:42
Please go to TOS control Panel - General Settings -Region&Language - Time, to change the time settings.
(34.68 KiB) Downloaded 109 times
anyway
Post by anyway » 20 Dec 2019, 15:12
Unfortunately your answer does not help.
I run a F2-210.
What you show is a predefined drop down menu with now possibility to enter a new server name.
Customer Service
Post by TMSupport » 27 Dec 2019, 10:16
Hi, sorry to tell you that we don't support changing the predefined time server in order to receive date and time from a local one at the moment, we have added it to our developing list. You will be noted as soon as it's ready.
iPeriod
Post by iPeriod » 19 Jul 2020, 09:39
@anyway
I've recently purchased a F4-210 and had the same issue. I didn't want to go near any Chinese services and the only other option asia.pool.ntp.org failed while updating the system time. The drop down list of NTP servers is limited and offers mostly ~~~.cn NTP servers.
SSH into the NAS as root and edit root's crontab replacing the NTP server with your local one.
ssh -p 9222 root@<nas hostname or IP>
List the current crontab, make sure it contained a NTP job:
crontab -l
Save the current crontab in case something goes wrong:
crontab -l >/tmp/crontab.root
Don't reboot or you will lose your backup crontab.
Now be careful and familiarise yourself with vi/nano editor commands:
crontab -e
Replace the current NTP name with your own, then save and exit
Check the crontab is correct:
crontab -l
If you need to revert back to the original crontab:
crontab /tmp/crontab.root
Customer Service
Post by TMSupport » 22 Jul 2020, 11:44
We will provide more NTP server options in coming update.
iPeriod
Post by iPeriod » 24 Jul 2020, 22:29
Thanks. You should also look allowing the user to set the frequency and timing of 'ntpdate' requests, individual user's requirements may vary in respect to time fluctuations. Look at the SSD TRIM timing UI, this would work for NTP as is.
Southland
Post by Southland » 01 Aug 2020, 06:36
I was about to report this same problem since all but two timer servers are in China, and all but one are in Asia. I recommend adding the following.
Worldwide: pool.ntp.org
United States: time.nist.gov
By the way, I recommend making the pool.ntp.org as the default since it will give you a local timeserver where ever you are located.
Customer Service
Post by TMSupport » 03 Aug 2020, 12:00
Thanks for the reporting, It will be transferred to the technical dept.
P37
Post by P37 » 06 Aug 2020, 04:10
The easiest way is login via ssh as root
ntpdate pool.ntp.org
Your ntp-Server is set.
You can also type it in the root-crontab
crontab -e
0 12 * * * ntpdate pool.ntp.org
TNAS F4-210, TOS 4.1.30
TNAS F4-220, TOS 4.1.30
