SSL key and certificate
I'm using the TOS 4.2.05 beta and I cannot get the system to apply an SSL key and certificate. When in the SSL part of the Security control panel, the system allows me to browse to find the files, but it won't let me apply them. I had the same problem in the previous beta, the only difference being that on 4.2.04, I couldn't delete unused self-created certificates and the menu responses were in Chinese, whereas now they are at least in English and I have been able to delete unwanted certificates. Any ideas on why I still can't apply the key and crt that I actually want?
Re: SSL key and certificate
Same issue here on 4.2.05 with my F2-220. I can also select the key/cert but the "Apply" button doesn't work when I click it. Nothing happens. Any luck here? Or feedback from devs?
Thanks for the reporting, we will test and fix it in later version.
