I moved some old HD contents over USB (I was dissapointed to know that I TNAS can't mount a non-empty HD in the tray).
Now, I cannot enter the folders, and I cannot change permissions. It seems root is the owner, and my user (admin) is not allowed.
Any help?
Permission problems on copied folders.
Re: Permission problems on copied folders.
Did you ever unplug the USB flash drive from your PC without safe ejection?We suggest you try to plug the USB flash drive into your computer to repair it, and then unplug the USB flash again after after safe ejection。
Yes, and it has happened with 3 different HD's. The files are already in the TNAS, why cannot change their permissions with the admin user?
I changed the permissions over SSH, but it's a really annoying bug
We will fix it in the coming release.
