I recently installed a WD 12gb drive into my F2-210, which I purchased a few months ago. I was experiencing some weird issues with TOS so I decided to use the "Reset system configuration" option and then re-install TOS.
I decided to download the image file from the Terra Master website and install TOS_A1.0_Install_ARM4.1_4.1.30_2008031214_2008061204.ins.
However, now the installation process has been sitting at 50% for 3 days! I restarted the process once to see if that would help but it did not. The HDD 1 light is flashing and I think I can hear the drive is doing something. Is it scanning every single sector of the 12gb disk before it installs? How long do I have to wait?
Why does re-installing TOS take so long?
Re: Why does re-installing TOS take so long?
Did you install a TOS 4.2 beta version before you re-install your TOS?
Hi Roy,
No - I also had 4.1.30 installed before I re-installed. The installation is still going. It's on the 4th day now. Should I start the re-install again? Or will that just lose all the progress I have made so far?
Please send an email to support(at)terra-master.com and we will arrange a remotely check for you.
OK - will do. Thanks.
