New F4-210 set up help
blue934
Re: New F4-210 set up help
Post by blue934 »
windows firewall was still blocking. I reran TNAS and this time the allow firewall option worked.
David
blue934
Post by blue934 »
I have 2 drives installed now, each as single. I am trying to map the drives and apply drive letters. I wish to see these drives on my network.
In TNAS PC, I click map drives. I login with the same credentials that I set up to in login to TNAS. The login window simply goes away, I don't get the map drives window. I get the same results if I use phony credentials.?? Do I need to set up new login credentials for the mapping?
Please make sure that SMB service has been enabled at TOS Control panel - Network services - File services.
Also please check whether there is any special characters in your login password, please revise it to the one without special characters and try again.
blue934
Post by blue934 »
It is enabled -named "workgroup". I have no special characters, just letters and a number.
Please enter \\your TNAS IP address such as \\192.168.1.XX in Windows file explorer to access your TNAS, and then check a folder and right click it and select "Map network drive" from the list to map your drive to see whether it's ok.
blue934
Post by blue934 »
Like this? No results found.
Explorer search for IP. png
Please see the following picture:
blue934
Post by blue934 »
I'm on win 7. I don't have that screen. I downloaded a file explorer for win 7 but it gives me the exact same screen as the screenshot I sent earlier.
blue934
Post by blue934 »
It looks like I get to the same spot by going My Computer-Network-TNAS
Could you right click a folder this way and map the network drive?
