NAS KO
RUNCAR
NAS KO
Post by RUNCAR »
My Nas F2-210, version 4.2.30 is not detected on the network.
At startup a BEEP, the four LEDs are on but no network indicator.
I tried this procedure (viewtopic.php?f=75&t=696), but it does not work.
Please kindly help me.
Hardfecx
Re: NAS KO
Post by Hardfecx »
Does it have a fixe Ip Adresse or dhcp? Can you ping it's ip?
If you don't know the ip adress, download "advanced IP Scanner" and search you local network for it. Maybe there was a network Problem and it changed the ip adress.
Otherwise you can reboot your Modem/Router, often, network Problems come from there.
