appdata is messed up
Permissions, domain/LDAP, power, security, notification and more.
V8Triker
Post by V8Triker »
I had a 502-Bad Gateway, so I had to re-initialise TNAS
I have two RAID instances. 1 and 5
When it all came back up, the Volumes had been assigned to the wrong RAID.
This was quite an easy fix as you can reassign the volume relating to a shared folder. This got all my data visible again.
However, I have an issue with appdata.
It looks like a new appdata was created on Volume #1, which is the RAID 1 instance.
I can see that the original appdata is on Volume #2, which is on the RAID 5 instance.
I can not reassign appdata to Volume #2. I assume because it is a "system folder"
Oddly, my MariaDb is still working, even though it is on the appdata on Volume #1
I would like to get my original appdata from Volume #1 and put it on Volume #2
I will then be able to backup the MariaDb files.
I will also get my Docker images/containers back.
Any thoughts?
Bikers know why dogs stick their head out the window.
TNAS F5-221
TOS 4.2.39-2203011626
3X WD RED PLUS 3TB (RAID5)
2X WD Green 2TB (RAID1)
1X WD 4TB USB
Hardfecx
Re: appdata is messed up
Post by Hardfecx »
I don't understand...you have a F2-221, right?
How do you create a Raid5 in that?
V8Triker
Post by V8Triker »
{L_BUTTON_AT}Hardfecx
Not sure how to reply to that question. Errrrrrrr, like this...
TNAS F5-221
1X WD 4TB USB
Hardfecx
Post by Hardfecx »
Ah, excuse me, in your descrition was online notized that you have only a F2-221 so I was a bit confiused that you have there a Raid5... ind a 2 HDD Nas oO. Sorry, my bad
V8Triker
Post by V8Triker »
Hardfecx wrote: 14 Jan 2022, 05:46 Ah, excuse me, in your descrition was online notized that you have only a F2-221 so I was a bit confiused that you have there a Raid5... ind a 2 HDD Nas oO. Sorry, my bad
Ooooops, sorry I see what you mean.
Will change my signature :)
TNAS F5-221
1X WD 4TB USB
V8Triker
Post by V8Triker »
Just to finish this thread off, when I power-cycled the TNAS I was then able to change the Volume assigned to appdata.
Saying that, before I power-cycled I did delete all the contents of the "new" appdata directory.
TNAS F5-221
1X WD 4TB USB
