manual standby / hibernation
Permissions, domain/LDAP, power, security, notification and more.
deejc
Post by deejc »
i have set power on / off schedule and tested WOL and its fine, but how can i send the Nas into standby manually from the command line so that the schedule still works ?
if i want the nas awake in the day i may send WOL, get some files then i want to send it back to sleep
F2-220 WITH 2 x WD RED 2TB RUNNING 4.2.17
Re: manual standby / hibernation
HI! You can set hard drive hibernation. Please go to Control Panel> General Settings> Hardware&Power> Hardware, and then enable hard drive sleep.
deejc
Post by deejc »
thanks, but not hard drive hibernation, i want the NAS to goto sleep like if the power on / off schedule is set to now
what is the command, like shutdown -s now ? or something else ?
like systemctl suspend or pmi action suspend
as you can activate your tnas by WOL, so you just need to shut it down as soon as your works is done.
deejc
Post by deejc »
Ok thanks so the power on / off timer will still work if I shut it down ?
sure!
deejc
Post by deejc »
Thanks a lot
