Dear,
thank you and good day for allowing me to write this new topic.
I recently bought a Terramaster F4-422 with 4 HDs.
I followed the configuration guide of my D-link DVA-5593 router with a static DNS from voip.com.
But I keep having remote connection problems (does not connect). Then I looked on this forum for some information on the settings on this router and on the internet. Unfortunately, no information was helpful.
My F4-422 has been regularly initialized and configured in Tnas, in fact, from the same network it works without problems, but when I connect remotely it is a failure.
I hope for your help to understand how to set up this router correctly.
Here is the hardware and software information:
NAS: F4-422
Router: D-Link DVA-5593
DDNS Static: active on voip.com
Sw: OS MAC
Thank you
Lello
DVA-5593_A1_EU_20200710 - NAS settings
Re: DVA-5593_A1_EU_20200710 - NAS settings
Have you mapped the port ?
- Mastercolumns
Thank you for attention,
Yes, j am map port:
Type: VNC (not defined)
IP remoto: ip DDNS
Port: TCP/UDP: 8181
Local Host: IP (F4-422)
I checked from www.portchecktool.com, but it confirms that the door is closed.
Yes, j am map port:
IP remoto: ip DDNS
Port: TCP/UDP: 8181
Please check if your network has internet ip.
