Unable to initialize as RAID 10
I am trying to re-initialize my fs-210 4 disk NAS to RAID 10 but the default of raid6 is not allowing me to configure as raid 10..... i Want mirroring in case of a disk failure....... thanking you in advance...
Re: Unable to initialize as RAID 10
according to the manual...... RAID is NOT an item I can select under storage options... see attached
You should backup your existing files and data first, and then delete the current volume and storage pool to configure the new RAID as RAID10. TOS reinstallation will not get to RAID re-create page.
not a solution..... your comment "TOS reinstallation will not get to RAID re-create page." if TOS wont let me then what will???
1. Reinstalling the TOS system will not affect the RAID
2. You need to set up RAID 10, only delete the original RAID (volume and storage pool), then choose to create in the volume and new set up RAID 10
Ps:Please save your data before deleting volumes and storage pools
{L_BUTTON_AT}rpnawrot
