Can't login
Permissions, domain/LDAP, power, security, notification and more.
Re: Can't login
It seems that it's not the reason of the device, either the HDD or the system. It's better to backup your data, and format your HDDs and start from scratch to see if it occurs again.
Arjan21
Re: Can't login
Post by Arjan21 »
{L_BUTTON_AT}TMSupport
Is there a way to backup a hdd with btrfs?
Arjan21
Re: Can't login
Post by Arjan21 »
How can I backup my data?
TMRyan
Re: Can't login
Post by TMRyan »
{L_BUTTON_AT}Arjan21
You can back up to other storage devices.(SMB or USB backup)
Arjan21
Re: Can't login
Post by Arjan21 »
{L_BUTTON_AT}TMRyan
I can’t access my nas and have to delete the hdd’s again. So I can’t use both methodes.
TMS
Re: Can't login
Post by TMS »
Please reinstall the system refer to this link method two: viewtopic.php?f=75&t=423
It is recommended to install the ext4 file system after backing up the data.
Arjan21
Re: Can't login
Post by Arjan21 »
{L_BUTTON_AT}TMS
Methode 1 won’t work because I can’t access my Nas.
Methode 2 won’t work either. Still can’t access, otherwise there was no problem.
TMS
Re: Can't login
Post by TMS »
Can TNAS PC find the device without any hard drives?
Or failed to reinstall the system?
Arjan21
Re: Can't login
Post by Arjan21 »
{L_BUTTON_AT}TMS
It succeed to reinstall, but after reinstalling the system I’m not able to acces the NAS anymore
TMS
Re: Can't login
Post by TMS »
Is it possible to let our engineer check it remotely?You can send an email to our tech team to confirm it.
