i'm not following you.. The wireless works fine It shows an IP address, and I can ping, and manage through the web interface via that IP address. I just want to set the default route to the wireless, BUT I do want BOTH connections. How would the new version resolve this issue and when will it be available? See below
--------From the TNAS ------
root@TNAS-AAF5:~# ifconfig
eth0 Link encap:Ethernet HWaddr 6C:BF:B5:01:AA:F5
inet addr:192.168.200.251 Bcast:192.168.200.255 Mask:255.255.255.0
inet6 addr: fe80::6ebf:b5ff:fe01:aaf5/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1583802 errors:0 dropped:36 overruns:0 frame:0
TX packets:70276 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:331741345 (316.3 MiB) TX bytes:24596037 (23.4 MiB)
Interrupt:12
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:14945 errors:0 dropped:0 overruns:0 frame:0
TX packets:14945 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2051924 (1.9 MiB) TX bytes:2051924 (1.9 MiB)
wlan0 Link encap:Ethernet HWaddr 1C:BF:CE:59:91:E9
inet addr:192.168.8.104 Bcast:192.168.8.255 Mask:255.255.255.0
inet6 addr: fe80:
ceff:fe59:91e9/64 Scope:Link
RX packets:133772 errors:0 dropped:515 overruns:0 frame:0
TX packets:10043 errors:0 dropped:4 overruns:0 carrier:0
RX bytes:13951045 (13.3 MiB) TX bytes:1410572 (1.3 MiB)
------ From the PC on the same network segment
C:\Users\moetop>ping 192.168.8.104
Pinging 192.168.8.104 with 32 bytes of data:
Reply from 192.168.8.104: bytes=32 time=11ms TTL=64
Reply from 192.168.8.104: bytes=32 time=28ms TTL=64
Reply from 192.168.8.104: bytes=32 time=7ms TTL=64
Reply from 192.168.8.104: bytes=32 time=44ms TTL=64
--------From the Tnas /etc/network/interfaces file
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config interface 'lan'
option ifname 'eth0'
option proto 'dhcp'
option ipaddr '10.18.13.58'
option netmask '255.255.255.0'
option gateway '10.18.13.1'
option dns '8.8.8.8'
option defaultroute 'false'
option dns2 '192.168.200.1'
option dns1 '8.8.8.8'
config interface 'wlan'
option ifname 'wlan0'
option proto 'dhcp'
option ipaddr '10.18.13.47'
option defaultroute 'true'
option dns1 '192.168.8.1'
config interface 'guest'
option ipaddr '192.168.2.1'
option _orig_ifname 'wlan1-1'
option _orig_bridge 'false'
----------On the Tnas the route shows this
root@TNAS-AAF5:~# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.200.1 0.0.0.0 UG 0 0 0 eth0
192.168.8.0 0.0.0.0 255.255.255.0 U 1 0 0 wlan0
192.168.200.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
---------- on the Tnas if I run the route commands it will change the default route.
root@TNAS-AAF5:~# route add default gw 192.168.8.1 wlan0
root@TNAS-AAF5:~# route delete default gw 192.168.200.1
0.0.0.0 192.168.8.1 0.0.0.0 UG 0 0 0 wlan0
