F2 NAS2 going ininstallation mode - can I reuse previously working HD
stefano.fornari
Post by stefano.fornari »
Hello all,
My F2- NAS2 started to go bad recently. It seemed to reboot and loose all settings like the services to startup and the date. Then it stopped to boot and after reading the FAQ site I rebooted it without the disks. Then I inserted one disk and pointed the browser to the NAS IPs, lending on the installation procedure. My question is: if I go on with the procedure, will it format the disk again? The disk led is blue and is the one formatted by the NAS.
Any help is very appreciated.
Stefano
Re: F2 NAS2 going ininstallation mode - can I reuse previously working HD
As for the mentioned model F2 NAS2, it's a very old model and has been stopped production for several years. The software is no longer updated, and no components to repair it.
It's suggested to get a new device and you will be offered with a suitable discount. You can contact support(at)terra-master.com for more information.
stefano.fornari
Device broken, how to recover the data? (was Re: F2 NAS2 going ininstallation mode - can I reuse previously working HD)
Thanks for your reply, and I will consider your offer. However my main concern right now, is not to loose my data. If I get a new device, it will format the disk.
So maybe the next step is: I can attach one of the disk to my linux machine through USB. How can I mount the disk to do a backup?
Thanks in advance.
Stefano
The technician here will help you backup the data from the old F2 NAS2 to the new TNAS.
Return to “Initialization”
