Got a brand new F4-423 last week, added 4x 4TB Ironwolf Pros and started using cloudsync.
Yesterday, My entire UI has turned to random characters, i was able to trigger a factory reset by remembering where to click but after the reset and a re upload of TOS5, the UI is still gibberish, has anyone come across this problem already ?
Thanks for any pointer !
UI has turned to gibberish
- Attachments
- NAS.jpg (18.55 KiB) Viewed 964 times
Re: UI has turned to gibberish
{L_BUTTON_AT}mpetit
This could be the web browser font compatible issue. Please try to modify the font settings in your web browser or you can change to another browser and try again. By the way, which language do you use as default in your browser? what is your native language?
You can also try to clean the browser cache and try again.
Yes, it fixed itself after a cache reset, so this might have been browser related. thanks for the hint !
Hi.
I have the same issue and clear browser cache don't work for me.
I already try with others browsers and still the same.
Any help ?
Any help ?
{L_BUTTON_AT}Carlos
Which language do you use as default in your browser?
Have you tried Google Chrome?
I attach one image with all my options.
I have already chosen one by one, and don't get any good.
Only Asian language seems to be right.
Problem solved after reboot my PC.
