I don't know why but the web UI stopped worked after installing TOS5 and reconfigured my NMVE M2 disk which after the update was erased.
So I have access to the terminal but I cannot access the web UI I tried even restore the /etc.default configs for nginx .
So far no success, Can anyone help me to force a system factory reset from the command line?
TOS5 Reset system via command line
Re: TOS5 Reset system via command line
At the end was able to reset via option 2 viewtopic.php?f=75&t=423 but well it was not convenient because for the M2 disk you need to unmount the whole thing.
