hello.
My problem may be silly but it is very annoying.
A clean installation of TOS 5, when installing an application only its icon appears if I have the interface in English and not in my native language (Spanish), any solution?
Thank you very much.
F2-221 Application Icons do not appear on the desktop
F2-221 + D4-300
10Gb RAM, 34Tb
10Gb RAM, 34Tb
Re: F2-221 Application Icons do not appear on the desktop
Go to app store, and disable and enable the app you have installed.
Same here. F2-221 running 5.0.129.
Installed Log Center, USB Copy and Terra Search. All installed successfully but do not appear on the desktop even after disabling and re-enabling as suggested above. This is the same using Chrome or Firefox.
The Control Panel/Application shows that they are installed.
You need to assign permission for the app to the user.
How do I do this? My user has full admin permissions. When I open the App center and open the installed app's icon and select "send to desktop", I get the Green "operation successful" popup. I don't see anywhere to create permission specific to the apps.
{L_BUTTON_AT}titanrx8
We have noticed related phenomena in some applications and are in the process of solving them.
I did find the edit function in the Control Panel/Priveleges/Application and had to add the admin named user (not the name used) to "Allow" and then the icons went to the desktop. I can now open the apps but the TerraSearch is still "preparing" after 2 days.
