F4-423. Installing TOS on M.2 NVMe SSD (instead of cache)
UpDaTe
Post by UpDaTe »
Hello!
Is it possible to install TOS on M.2 NVMe SSD drives?
I don't want to use them for cache, but would like to make a volume (RAID 1) out of them and install TOS there
And HDDs should only be used for data
Re: F4-423. Installing TOS on M.2 NVMe SSD (instead of cache)
It is possible. As TOS does not limit them only for cache.
UpDaTe
Post by UpDaTe »
Ок, this is good
What size M.2 NVMe SSD do you need to put TOS on them?
Are there any instructions for installing TOS on an M.2 NVMe SSD?
4GB is good enough for TOS.
You do not need a special instruction to do that, you just set your M.2 disk as a single disk, then the TOS will be installed on it.
UpDaTe
Post by UpDaTe »
If I install two M.2 NVMe SSDs, I can build Radi1 out of them, right?
Do you have instructions on how to install an M.2 NVMe SSD into NAS F4-423?
TMAY
Post by TMAY »
Yes, you can build a raid1, M.2 NVMe SSD mounted to a NAS F4-423 in the same way as a regular disk.
{L_BUTTON_AT}UpDaTe
Sure, we will public a video soon.
UpDaTe
Post by UpDaTe »
OK thanks
If TOS is installed on the M.2 NVMe SSD, will all the programs that I install later also be installed on the M.2 NVMe SSD?
You can specify where the app is installed.
go to app center > settings, select the volume you want to app install to.
mcille
Post by mcille »
I cannot install system on the M.2 disk by default TOS get installed on the 4 disk array (raid 5)
Return to “Initialization”
