F2-210 login
Dokey
F2-210 login
Post by Dokey »
Hi all, not sure if this is the right section to ask in, so apologies if not.
I have the f2-210 coming up in the TNAS window, which I can select, but for some unknown reason when it takes me to the login page, it no longer recognises my, or any email address/password.
Can the whole system be reset so I can start afresh with the login details?
Thank you in advance for any help,
Ryan
Re: F2-210 login
Did you mean you forgot your password and username?
Dokey
Re: F2-210 login
Post by Dokey »
TMroy wrote: 29 Apr 2022, 23:17 Did you mean you forgot your password and username?
That is an easier way of saying it, thank you :lol:
Yes I believe I have forgotten my username and password :(
TMnorah
Re: F2-210 login
Post by TMnorah »
Hello, you can reinstall the system to reset your account password. For details, please refer to the following guidelines:viewtopic.php?f=76&t=423
Dokey
Re: F2-210 login
Post by Dokey »
Thankyou for the help, all sorted.
Have a good weekend.
Ryan
Return to “Initialization”
