F2-210 issue
minimicro
F2-210 issue
Post by minimicro »
I have an F2-210.
Recently, it disappeared from the interface of my box, I changed cable and network port but ping stay KO.
Nothing happens when I long press the power button.
If I want to stop it, I have to unplug the power ...
Thanks,
(Sorry for my bad english, i'm french)
TMRyan
Re: F2-210 issue
Post by TMRyan »
First of all, you need to check that the network of TNAS and the computer are in the same environment, you can try to boot up without inserting the hard disk, and then use the TNAS PC to search for TNAS.
