Is it possible to install an alternative OS on the Terramaster F2-210?
For example, FreeNAS or XPEnology ?
Re: Is it possible to install an alternative OS on the Terramaster F2-210?
Those environments have support forums. Check if anyone has reported installing those. Be warned, while it's usually possible to install os's from other sources, drivers for things like fan speed, LED indicators etc might not be available unless you write them yourself.
- crisisacting
it turns out only a native TOS and nothing more?
