F4-210 - 4.2.15 - Unable to create new volume
fadege
Post by fadege »
First I see only Ext4 and not BTRFS choise.
Then the process begin but after 2 seconds it's stop.
So.. no Volume 1! What wrong?
Re: F4-210 - 4.2.15 - Unable to create new volume
The first volume: volume #1 should have been created during your TNAS initialization. may i know What did you do to your TNAS? please let me know, i have the same question, where is the volume #1?
fadege
Post by fadege »
I really dont know: I add a second HD, but I was unable to add files for a permission error.
Then I install the new OS, 4.2.15, hoping it will be usefull. Then after a lot of start and re-start (I get a lot of TNAS not found error) I get no volume one, so I try to create it again...
fadege
Post by fadege »
Now I am unable to login: "no device was found".
I try with and withour HD. The firewall is off. No way. No more TNAS....
Hi! Please refer to the article for troubleshooting.
viewtopic.php?f=75&t=2250
Return to “Initialization”
