Boot Order Blocked in BIOS - F2-422
dranivil
Post by dranivil »
Hi, I am trying to install a different operating system on F2-422 model. The operating system works fine, but for it to work I need to have a USB plugged in and booting from it. Since the BIOS does not let me change the boot priority (it is blocked!). Yes, I can UEFI mode if I boot from USB, but this operating system only works in legacy mode, so it is not an option for me.
How could I change the BIOS boot priority? Perhaps a BIOS update is necessary to correct this
Re: Boot Order Blocked in BIOS - F2-422
It will boot from internal USB first when your F2-422 is booted up without any HDDs or your HDDs are not installed with TOS.
It’s not allowed to change the boot order in BIOS.
Try to remove the USB stick before you boot, by doing this, you need to open the cage and find the USB boot stick on mother board.
dranivil
Post by dranivil »
I find it very bad on the part of terramaster that they intentionally limit the BIOS to interfere with the startup of third-party software.
TMroy wrote: 08 Jun 2021, 23:48 Try to remove the USB stick before you boot, by doing this, you need to open the cage and find the USB boot stick on mother board.
If I unplug the usb will it let me change the boot order?
{L_BUTTON_AT}dranivil
This article could help to answer. https://joelduncan.io/freenas-on-terramaster-f2-221/
dranivil
Post by dranivil »
@ TMroy
I already read that article before installing anything. But in my case 2 things happen:
- The software I use does not work in EFI, I have to put it in legacy mode and therefore it always boots from the hard disk.
- My BIOS has fewer options than the F2-221. The "CSM configuration" section does not appear in my BIOS.
This is all I can do for you. My job responsibilities do not include guiding you to break in our own device.
dranivil
Post by dranivil »
With all due respect, the device is my property and I am responsible for what I do with it. It is Terramaster that has deliberately limited a product.
Sure, you are right, you own the device, you can do whatever you want. Unless the hardware of the device is artificially damaged, the warranty service is still valid.
sianderson
Post by sianderson »
dranivil wrote: 12 Jun 2021, 22:35 I find it very bad on the part of terramaster that they intentionally limit the BIOS to interfere with the startup of third-party software.
what a quite odd comment to make, would you have an issue if you bought a renault car and a BMW door doesnt fit? and then complained to Renault that they intentionally made their door a different shape to a BMW one? after all you own the car so a different manufacturers part should fit?
F2-210
4.2.43
