It would be nice to see TOS not go through the entire setup process when I add a new hard drive to any Terra-Master system. There should be some kind of option in place to bypass this feature instead of having to "create a new account" then go through setting up the new drive as if the system had no drives installed. I am using the latest version of TOS. I haven't started using my Terra-Master, I am waiting until I get all the HDD's first.
Thanks,
TOS: F5-421 and adding an HDD
Re: TOS: F5-421 and adding an HDD
Do you want to create multiple single disks or RAID? what‘s problem?
