Memory and access issue after upgrade to 4.2
goullec
Re: Memory and access issue after upgrade to 4.2
Post by goullec »
EDIT: I can access to the login page via the full URL (/tos/index.php?user/login)
I set admin password and then when i try to login nothing happen, maybe it's come from the web server or js code himself.
TMS
Post by TMS »
It's suggested to let our engineer help you by remote session first. You can ask this service by sending email to support(at)terra-master.com.
From the screenshot you shared, TOS has not been updated to 4.2.06 successfully, it is still on 4.1.x, there is something wrong during update.
Please try to re-install the TOS with the latest installation package.
here is how to re-install your TOS viewtopic.php?f=75&t=423
4.2.06 installation package for ARM 410 series models https://dl.terra-master.com/cn/TOS_A1.0 ... 041414.ins
goullec
Post by goullec »
Hi, it's a x86 processor, you give me the arm link
TMS
Post by TMS »
Please refer to this link to get the instructions:
viewtopic.php?f=28&t=1026&hilit=x86+version
goullec
Post by goullec »
Hi thank's for your reply.
It doesn't work, I'm getting stuck on the loading screen and by specifying the url i can't login.
Do you have a procedure for mounting the raid from the ssh access available during installation (linux from boot)? This allows me to recover my data and erase my drives for starting from 0. I can't stay in such situation.
goullec
Post by goullec »
EDIT :I took out my two iron wolf hard drives, then put in an old hard drive. I can connect to the NAS. I then add my two iron wolf hard drives. If I create a new raid pool 1 on it, will the data be deleted?
goullec
Post by goullec »
EDIT 2 : I have successfuly rebuilding the old raid with a the ssh connection. Now i can access to half of my old file.
The second half is encrypted. I encrypt the share directory in the gui. Wich method are you using with ecryptfs (the command) for decipher it with the passphrase?
Return to “Initialization”
