Easy way to Update PHP
Tell us your most wanted new features, or recommendation.
TiggerMS
Germany
Post by TiggerMS »
Hello, it would be nice to set the PHP version. I needed 7.2 or greater on the web server.
Re: Easy way to Update PHP
will check and let you know if it is possible.
HammyHavoc
Post by HammyHavoc »
What was the verdict?
We will update current Web Server and add PHP configuration in near future.
TiggerMS
Germany
Post by TiggerMS »
Hello, I am now using TOS 4.2.07 and there you can install php version 7.4. But unfortunately the web server is still using the old php version 7.1.xx. Can I get the web server to use 7.4?
Thank you so much for your help,
Markus.
TMS
Post by TMS »
It will be released soon, php 7.4 will be used.
Return to “New Features Wanted”
