ist there a possibility to deactivate and reactivate USB Ports by a script?
Deactivate - reactivate USB-Ports
Re: Deactivate - reactivate USB-Ports
Did you mean USB port? or USB device?
If USB port, why do you need to activate/inactive your USB port?
{L_BUTTON_AT}TMroy
Well because I have 2 USB drives connected on the Nas ( for USB Copy Backup) and so they are all day on power. But if I remove the USB cable, they are powered off. So I wanted a script that deactivate the USB port (so no more power on it) and activate it before backup to the USB Disks is starting.
Then i think you can do so. here is an article for your reference.
{L_BUTTON_AT}TMroy
Thank you M8! I did that several years ago on a Windows XP machine but in cmd as a *.bat file.
But how can I start and stop the script on the Nas or have those commands to be sent frem an Pc to the Nas (F4-210 - Raid5 - 4x 2TB)
{L_BUTTON_AT}TMroy
Sorry, but I can't edit my previous post...
I can't find any terminal application (so I can't create a script like a *.bat file on Windows Pc's) and no option to run a schedule file. By the way, I have no Linux machines in my Network....
{L_BUTTON_AT}TMroy
I tried with "devcon" but that's only for the Windows machine where I can enable/disable Usb ports... but over Network it doesn't work
{L_BUTTON_AT}TMroy
Me again...(why I can't edit my first post after several Minutes because so I have to create always a new one...).
I tried now with SSH and I can unmount my USBShare but then they are still powered on. I didn't find any command to deactivate the USBport so that is no more power on it... Is that even possible?
But again, even if it is possible, I have to launch those commands from a Pc wich is running, right?
{L_BUTTON_AT}TMroy
Maybe attach the USB drives to the PC where you can control the drives' power state? Not sure if USBcopy can work with virtual disks and performance might be poor but you get to power down disks.Hardfecx wrote: ↑20 Nov 2021, 15:45 Me again...(why I can't edit my first post after several Minutes because so I have to create always a new one...). I tried now with SSH and I can unmount my USBShare but then they are still powered on. I didn't find any command to deactivate the USBport so that is no more power on it... Is that even possible? But again, even if it is possible, I have to launch those commands from a Pc wich is running, right?
You are not able to control the USB power by script, no possible.
